The need for heavy duty springs if you are adding weight.
Julian
Standard 275/70 R16 Dunlop Grand Trek @ 32psi. The height of the step on the back bumper is exactly 25" above the ground. Wheel arch clearances fore & aft look pretty similar.
Anyone else got those sized tyres & a tape measure?
CB
Mine is nearly 25" as well.
Cheers,
Matt
'91 HDJ80
Landy V8 80"
35cc radio controled Beetle, V fast!
----- Original Message -----
To: [Email address removed]
Sent: Friday, January 28, 2005 2:23 PM
Subject: Re: [ELCO] The need for heavy duty springs if you are adding weight.
Julian
> What size tyres do you have and how high is the top of the rear bumper - perhaps
> you could compare it with someone else here with a stock setup - I wouldn't be
> surprised if yours is a couple of inches lower than others.
CB
Further Info: http://www.landcruisers.info/lists/
That sounds a bit low, our 93 with standard suspension (which I thought
was low from old age) but 285 tyres is 27" to the step on the rear. Even
allowing for the 285's 25" seems low?
Never measured it before but the 94 is 33" to the step.
Jon.
