The need for heavy duty springs if you are adding weight.
Matt & Jon
Well, 25" seems to suit me, and it still leaves a visible upwards slope of the running boards towards the rear (when looked at from the side), ie it doesn't look down at the back vs the front.
In fact, if anything, it leaves the horse trailer a little nose up with a tendency to lock the brakes on its front axle when empty. I've been tempted to move the towball down to the lowest set of holes on the hitch, but that will take it below the reinforcing plate behind, and increase bending moment on the hitch assembly. And I've never had stability problems towing the horses, so I think it's a case of "let sleeping dogs lie".
Christopher Bell
Devon, UK
1996 1HD-FT (possibly suffering from brewer's droop)
On Behalf Of Jon Wildsmith
That sounds a bit low, our 93 with standard suspension (which I thought was low from old age) but 285 tyres is 27" to the step on the rear. Even allowing for the 285's 25" seems low?
Never measured it before but the 94 is 33" to the step.
Jon.
Christopher,
You could try putting taller tyres on the horse trailer then you could get
away with elevated springs on the 80.
Anthony graham
1994HDJ801HD-T
West Wales
UK
_____
Behalf Of Christopher Bell
Sent: 02 February 2005 12:54
To: [Email address removed]
Subject: RE: [ELCO] The need for heavy duty springs if you are adding
weight.
Matt & Jon
Christopher Bell
Devon, UK
Jon.
