chris lc90
- Aug 18, 2010
during winter a lot of mud stucked to my radiator.(i didnt know that
)the first days of summer i noticed that the temperature remain too high..my first think was the water pump, or the main gasket of cylinder cover or thermostat.i checked immediately the raditor for leakage-it was clear.no bubbles to the open cap of radiator (so i didnt have crack to cylinder or corrosion to the flat surface of the maingasket),no leakage from the water pump.
when i flushed the radiator everything was ok..but needs to take it out and wash it better..so i changed also the fluid.and thermostat.has 170.000 km but i dont know when changed the previous owner thermostat or ..the fluid..when i opened i saw the jiggle v/v in 45 deg right side instead of 12 oclock position (or -30 deg +30 deg deviation).also i checked the old and the new thermostat together .warm a pot and when the temp rise to 40 deg celsious i put them inside..the old one had one small delay during opening and close more quickly when i took them out of the water.
http://www.youtube.com/watch?v=LE5yBV3FQzo
http://s815.photobucket.com/albums/zz71 ... e%20valve/
