MisterCruiser
- May 28, 2014
Can anyone recommend either this foxwell diagnostics or a Stream copy?
I need it to read the abs system, not just engine codes. Does anyone here have the foxwell unit and does it work ok on a 2004 120 model?
I’ve had bad experience of multiple VCDS copies from eBay where none worked and just bought the genuine in the end as I use it a lot. I don’t mind buying the foxwell if it is 100% compatible and if the Stream versions are a bit hit and miss whether you get a good copy.
Also, can anyone provide a link to a recommended Stream version please?
Foxwell NT530 Professional Multi-System Scan Tool for Toyota, Lexus and Scion Vehicles - [Leaving Land Cruiser Club]
