Too cool, or not ?
frank rabbets
There have been several comments about the 80 diesel engines running too cool in this country. If this is the case then why didn't toyota fit a higher temperature thermostat? Would it be possible to fit one rather than use the rad blind?
Frank
Not sure they run too cool frank, i think rather they can handle a lot higher temps without overheating.
i pull the rad blind down once weather is regularly below freezing so it warms up quicker.
One of the first mods on my 70 was to fit a higher rated thermostat. That was 120,000 miles ago. Warms up quickly, whatever the weather and rarely needs the electric cooling fan.
Roger
SOunds good.
Im after a webasto thermo top, but not exactly for the same reason.
Opening temp 74-78 deg C.
Min 10mm lift at 90 deg C.
