Tractionman
- Oct 11, 2013
Karl2000, went out earlier this am and did a double, double check. I plugged in the trailer light tester, held the yellow button in (as required), all lights come on indicating all is good. Then plugged in a trailer board from the garage, All lights function and flasher rate normal, as on seperate trailer. That leads me to the conclusion I had earlier, that your one light indicated is the only wiring correct, there is a problem with the rest.Don't worry, doesn't take much to confuse me mate!
On my tester, the light comes on if it gets a voltage between ground and the particular pin; i tested the tester first by putting 12V across each pin and watched each light illuminate.
When I turned the lights on, or flashed the hazard lights or indicators, the correct lights on the tester lit up. But when everything was off, the left indicator light on the tester was illuminated, because of that 4V or so voltage that I can't explain except maybe a bad relay.
BTW I took the cover off the relay and it looks fine, nothing obviously burnt or damaged.
Does anyone else have a voltage between yellow and white on that relay, when the indicators are off? I assume not!
Thanks!
The problem must lie within and/or including the socket.
Has anyone 'modified' the Toyota loom at the rear end connections with scotchlocks, they can be a constant source of problems, especially when exposed.
