Trailer Connector - No right-hand turn signal power
Kevn
united_states
I'm wiring up trailer lights and would like to do it as cleanly as possible. Only using the trailer connector and ground. I found a helpful youtube video. Thanks if you are on the forum
Before I tap the right side wiring, I was hopeful that maybe someone had solved this one already?
I started chasing this GY wire up the passenger side of the truck a 1996 KZJ90 to the front door so far.
Thanks for any insights or ideas!
I think the main loom comes up the left hand side of the car. My trailer connector is wired up here. I think there is a factory plug for it. It's all behind the cubby where the jack is kept.
I'm guessing you have power for the right-side turn signal at the factory plug?
Yes I am pretty sure and ignition power too if you want to use a repeater (e.g. if you have a bullbar with indicators already). Might be worth looking for the plug and checking it out with a test light.
That's odd. Mine just has a single plug with everything going through that. But it's an Australian domestic market model.
