Transfer Box Breathers
Paul
I have been doing all the usual stuff and thought it was time to sort the breathers as just corrected an oil leak from the speedo drive and changed the oil.
Now, I have searched though all the stuff on here and yes there is loads of mods which I will do, but still cant find the actual breather as it is right now, tracing the pipes from the transfer and main gearbox forwards to the bulkhead I loose sight of the pipe and best guess is that are connected into the auto box dipstick pipe as there are two connected in there that don't appear to do much. I have seen that people have referred to the breather pipe as a bugger to get too.
Any help would be good.
Would recommend a rubber hose rather than the plastic hoses which can become brittle in the cold.
Also, ensure to allow for max suspension flex rather that the pipes getting ripped off for being too short
No worries there, just need to find where to connect it to.
Transfer box breather eventually runs to the differential lock casing.
Regards
