zooey
- Sep 7, 2015
I've had a fair few 70 series European trucks and can safely say that I completely love them! I've got an import body of the same age and specifications as the one that you are looking at. It's the best condition out of the 4 keepers that I have ! So there's a few down falls with the 71's in this respect. As they were made for the JDM market they werent sealed as well on the underside from my experience. The Japanese trucks were intended to be used for a limited amount of years. Due to emissions. .
So as I look at your pic of the lj71. Its in nice looking condition.
If you look in the back doors lift the rear boot carpet by where the jack is stored.and the opposite side same area . Is there any sign of rust bubbling in the paint on the boot floor? Then check the underside directly underneath on the other side of the rear plastic bumper corner to see if it is corroded there by the side of the exhaust. A classic rust point. Check around the rear wheel arches to see if it has corrosion there.
A good way to judge how "well" it is by when it was imported. . My gold/brown left Japan in 2005.. so pretty good. . But my kzj71 was exported in 1999 so not so well off rust wise!
These are highly modifiable trucks so dont worry too much about the engine performance as it can be upgraded. . In my opinion its all about how solid the body is. Imports are generally better speced trucks .. more comfortable with better seats and electics. They all have the bigger better braking systems so winner there..
If its solid I'd say Go for it! Be good to spend a bit getting it fully undersealed and to waxoil the cavities. .
Good luck with it. . Once you have one you will not regret it![]()
Thank you. Your suggestions are on my list of "kick the tires as my proxy"....but from everything, every bit of input you all have shared. Your advice. (Far as I am concerned it is a done deal and all I need to do is show husband the way.) Many thanks. And I will return, hopefully, to ask beginner advice on care.
