mine started that last week, when i went looking i noticed a little oil spray on the manifold heat shield - the back side of the flexible hose connecting turbo to that long metal intake pipe that goes over the top had a 2 inch horizontal split in it. had to pull the flex hose off to find the split.
I had a great whistle 'from the turbo' it sounded just like a dump valve......so after hard acceleration as you lifted the throttle you'd get a "ppooompphh".......sounded great actually but alas it was just a hole in the flex pipe exhaust section and not some fancy aftermarket modification
