twistsed radius arm...
Hi,
I have been struggling to find this clanging(deep erratic clunk) noise under
my car at very low speeds.
Believe I have narrowed it down to be the radius arm bush (or trailing
arms?)at the back of the axle, its lost its sleeve in the middle.
Now I have been lying under vehicle with my head torch on (its dark) and I
believe the arm is twisted, probably caused by some extreme axle twist or
going to fast.
The arm looks like its twisted a bit at the end of arm where it joins the
axle at the back bush.
Has anyone else done this and would anyone think ones of an LJ78 would fit?
Martin.
Hi Martin,
Do you think they can be twisted back with a bit of heat?
07971 540362
[Email address removed]
Hi Julian,
I have hopefully found some down in Salisbury...
Would imagine they could be twisted back although it could be quite a task
Have a good weekend unfortunately I could not make it :-(.
Speak to you soon.
Martin.
-----Original Message-----
Behalf Of Julian A.R. Voelcker
Sent: 18 April 2008 23:40
To: [Email address removed]
Subject: RE: [ELCO] twistsed radius arm...
Hi Martin,
07971 540362
