- May 26, 2014
Anyone on here have knowledge/experience of a four point torsion free sub frame?
Did you reuse the existing mounts jon? Was it a flatbed you put back on it?Ian Rubie had a unimog that had that arrangement and I built a tray back on it for him.
The mog came with a box which Ian cut up to leave just the mounting system and then I made a flat bed frame with a roll over hoop and stuck that on top. This picture might help:
stu, If that's the case its music to my ears, its been doing my head in tbh. ive been sent pictures of fancy mounting systems that to my eyes still span both chassis rails, then they have the "third mounting point" which pivots, but its still spanning both chassis rails!! ok they don't have the long lengths of plate running along the chassis that's normally added when fitting to a lorry, maybe the third mounting point offers this extra spread of load so the plates are not needed?The hiabs I have seen on mogs have always mounted behind the cab the same as any other lorry. Is the rear of the chassis that flexes so along as it moves further back you will be fine.
