Following my winch installation I decided that I no longer required my dedicated Hi-Lift winch kit
So on the eBay it went and sold fairly well making about £50
I spent plenty of time playing with it in different configurations and there's no doubt in my mind that there's a place for a Hi-Lift as a winch, but I'm not convinced that one needs the Hi-Lift winch kit to make it one as nice as it is to have another bit of kit
Then, when Ben fell off the road we needed to put some side ways load on his truck and the Hi-Lift was the tool for the job. Luckily I'd kept my towing chain with clevis hooks either end even though I'd cut it down in length from four meters to two in another of my weight shedding exercises. The chain is pretty essential for taking up the largest part of the slack in the straps, but because I'd sold my Hi-Lift winching kit we didn't really have an elegant way of attaching the rigging to the the Hi-Lifts shoe! Hence having to strap the Hi-Lift to the chain once we had taken up as much strain as we required, just in case the chain slipped from off of the shoe.
The clevis chain was also very useful for easily and quickly taking up the slack in the safety strap as we winched Bens truck back up onto the flat.
After returning home and stowing all the gear away I popped round to see my m8 Pete at his steel fabrication workshop to chew the fat over the weekend away and to see if we could find a more suitable solution to attaching the chain to the jacks shoe when using it for winching. Pete suggested using my Hi-Lift lift M8 as it's some thing that I carry anyway
So I had a play and it seemed like a good plan should I require the use of my Hi-Lift as a winch ever again
A couple of days later Giles came around for a cupa and to show me his newly created center console
We got to chatting about what Pete had suggested and agreed that it was a great solution, but I could tell he had a glint in his eye as he was pouring over my Lift M8!!!
A couple of days after this Giles dropped the little beauty that he'd made for me around
He's a good m8
It's lovely
I drilled the hole at the top of my Hi-Lift's bar out to 20mm to accept the pin of a larger bow shackle and now have a pretty sexy looking Hi-Lift winching system again
Should I ever need one
And because I cut my chain in half down to two meters there's room in the chain box for the G-Adapter and two Bow shackles to be ready and waiting for use
I left the adapter with Pete for a couple of days and he got it Galvanized for me to boot
Can't wait to get it out in anger now
He's a good m8
