Walbro pump and EGT
SGVsbG8gR2FyZXRoLA0KDQpJIGd1ZXNzIEkgbWlzc2VkIHNvbWV0aGluZzogd2hhdCdzIHVwIHdp
dGggdGhpcyBXYWxicm8gcHVtcCB0aGF0IG9uZSBzaG91bGQNCmdldCAiYmVmb3JlIGRvaW5nIGFu
eXRoaW5nIHdpdGggdGhlIGluamVjdG9yIHB1bXAiPz8NCg0KSSBoYWQgdGhlIGVuZ2luZSByZWJ1
aWx0IHJlY2VudGx5IChwaXN0b25zLCByaW5ncywgLi4uKSBhbmQgcHV0IHNvbWUgbmV3DQppbmpl
Y3RvcnMgYnV0IEkgc3RpbGwgdGhpbmsgc29tZXRoaW5nIGlzIHdyb25nIHdpdGggdGhlIGNvbWJ1
c3Rpb24gKGFjaWQNCmdyZXlpc2ggc21va2UgY29tZXMgb3V0IG9mIHRoZSBleGhhdXN0LCBtYWlu
bHkgd2hlbiBlbmdpbmUncyB3YXJtKS4NCg0KVG9kYXkgSSdtIHN1cHBvc2VkIHRvIGJyaW5nIHRo
ZSBjcnVpc2VyIHRvIGEgZGllc2VsIHNob3AgZm9yIGEgZmlyc3QNCmRpYWdub3N0aWMuIEkgZ3Vl
c3MgY2hlY2tpbmcvYWRqdXN0aW5nIHRoZSBhZHZhbmNlIHdpbGwgYmUgYSBnb29kIHN0YXJ0IGJ1
dA0KSSdsIGhhdGUgdG8gaGVhciB0aGUgZ3V5IHNheSBoZSBuZWVkcyB0byBvcGVuIGl0IHVwIDpv
KA0KDQpEbyB5b3UgaGF2ZSBFR1Q/IElzIGl0IHBvc3NpYmxlIGZvciB0aGUgcGVvcGxlIG9uIHRo
ZSBsaXN0IHdpdGggODAgY3J1aXNlcnMNCih3L28gaW50ZXJjb29sZXIgO28pIHRvIGdpdmUgbWUg
c29tZSBudW1iZXJzIGF0IGxldCBzYXk6DQotIGlkbGUNCi0gY3J1aXNpbmcgb24gYSBmbGF0IHJv
YWQgYXQgNTBLUEggKDMxTVBIKQ0KLSBNYXggbG9hZCAoc3RlZXAgdXAgaGlsbCwgInBlZGFsIHRv
IHRoZSBtZXRhbCIsICBmcm9tMTUwMHJwbSB0byAyMDAwcnBtLCBpbg0KM3JkIGdlYXIgZm9yIE1U
IGFuZCBzaGlmdGVyIG9uIDJuZCBmb3IgQVQpLg0KDQpJJ2xsIGRvIGEgY291cGxlIHJ1biB0b25p
Z2h0IG9yIHRvbW9ycm93IHdpdGggbXkgc2V0IHVwLiBUaGFua3MgaW4gYWR2YW5jZS4NCg0KQ2hl
ZXJzLA0KDQpMaW8sIFBhcmlzIGNvdW50cnlzaWRlLCBGcmFuY2UNCic5MiBIREo4MCwgZ2V0dGlu
ZyByZWFkeSBmb3IgZmlyc3QgQWZyaWNhbiB0cmlwIChNYXJvY2NvIGFwcmlsIDA3KQ0KDQpGcm9t
OiAiR2FyZXRoIEpvbmVzIiA8R2FyZXRoLkpvbmVzQHBhdGVudC5nb3YudWs+DQpTdWJqZWN0OiBS
RTogW0VMQ09dIEluamVjdG9ycw0KUmVwbHktVG86IGVsY29AbGFuZGNydWlzZXJzLmluZm8NClNp
bW9uLA0KDQpCaWcgc2lnaCBvZiByZWxpZWYhDQoNCkhhdmUgeW91IGdvdCB0aGUgV2FsYnJvIHB1
bXAgeWV0Pw0KDQpJIGhhdmUganVzdCByZWNlaXZlZCBhbm90aGVyIG9uZSBmcm9tIFJvbiBHcmVn
b3J5IGF0IEFQRSBpbiB0aGUgVVNBDQp3aXRoaW4gMTAgZGF5cyBvZiBvcmRlcmluZyBpdC4NCg0K
SSB3b3VsZCBmaXQgdGhlIFdhbGJybyBwdW1wIGJlZm9yZSBkb2luZyBhbnl0aGluZyB3aXRoIHRo
ZSBJbmplY3Rvcg0KcHVtcC4gRmFyIGNoZWFwZXIgYW5kIGxlc3Mgc3RyZXNzZnVsLg0KDQoNCg0K
LS0gRGlzY2xhaW1lciAtLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0NCkNlIG1l
c3NhZ2UgYWluc2kgcXVlIGxlcyBldmVudHVlbGxlcyBwaWVjZXMgam9pbnRlcyBjb25zdGl0dWVu
dCB1bmUgY29ycmVzcG9uZGFuY2UgcHJpdmVlIGV0IGNvbmZpZGVudGllbGxlIGEgbCdhdHRlbnRp
b24gZXhjbHVzaXZlIGR1IGRlc3RpbmF0YWlyZSBkZXNpZ25lIGNpLWRlc3N1cy4gU2kgdm91cyBu
J2V0ZXMgcGFzIGxlIGRlc3RpbmF0YWlyZSBkdSBwcmVzZW50IG1lc3NhZ2Ugb3UgdW5lIHBlcnNv
bm5lIHN1c2NlcHRpYmxlIGRlIHBvdXZvaXIgbGUgbHVpIGRlbGl2cmVyLCBpbCB2b3VzIGVzdCBz
aWduaWZpZSBxdWUgdG91dGUgZGl2dWxnYXRpb24sIGRpc3RyaWJ1dGlvbiBvdSBjb3BpZSBkZSBj
ZXR0ZSB0cmFuc21pc3Npb24gZXN0IHN0cmljdGVtZW50IGludGVyZGl0ZS4gU2kgdm91cyBhdmV6
IHJlY3UgY2UgbWVzc2FnZSBwYXIgZXJyZXVyLCBub3VzIHZvdXMgcmVtZXJjaW9ucyBkJ2VuIGlu
Zm9ybWVyIGwnZXhwZWRpdGV1ciBwYXIgdGVsZXBob25lIG91IGRlIGx1aSByZXRvdXJuZXIgbGUg
cHJlc2VudCBtZXNzYWdlLCBwdWlzIGQnZWZmYWNlciBpbW1lZGlhdGVtZW50IGNlIG1lc3NhZ2Ug
ZGUgdm90cmUgc3lzdGVtZS4NCioqKg0KVGhpcyBlLW1haWwgYW5kIGFueSBhdHRhY2htZW50cyBp
cyBhIGNvbmZpZGVudGlhbCBjb3JyZXNwb25kZW5jZSBpbnRlbmRlZCBvbmx5IGZvciB1c2Ugb2Yg
dGhlIGluZGl2aWR1YWwgb3IgZW50aXR5IG5hbWVkIGFib3ZlLiBJZiB5b3UgYXJlIG5vdCB0aGUg
aW50ZW5kZWQgcmVjaXBpZW50IG9yIHRoZSBhZ2VudCByZXNwb25zaWJsZSBmb3IgZGVsaXZlcmlu
ZyB0aGUgbWVzc2FnZSB0byB0aGUgaW50ZW5kZWQgcmVjaXBpZW50LCB5b3UgYXJlIGhlcmVieSBu
b3RpZmllZCB0aGF0IGFueSBkaXNjbG9zdXJlLCBkaXN0cmlidXRpb24gb3IgY29weWluZyBvZiB0
aGlzIGNvbW11bmljYXRpb24gaXMgc3RyaWN0bHkgcHJvaGliaXRlZC4gSWYgeW91IGhhdmUgcmVj
ZWl2ZWQgdGhpcyBjb21tdW5pY2F0aW9uIGluIGVycm9yLCBwbGVhc2Ugbm90aWZ5IHRoZSBzZW5k
ZXIgYnkgcGhvbmUgb3IgYnkgcmVwbHlpbmcgdGhpcyBtZXNzYWdlLCBhbmQgdGhlbiBkZWxldGUg
dGhpcyBtZXNzYWdlIGZyb20geW91ciBzeXN0ZW0uDQo
Hi Lionel,
Idle in park about 100-115 degrees C
At 50kph about 180-200 at 100km/h 270-320 slight changes in grade make a
big difference.
WOT at much higher speed 760C stock 720 intercooled
All numbers are pre turbo measured with a fast response 1.5mm pyro probe
tip taken directly above the intake to the exhaust housing.
Cheers,
Craig.
HEBERT Lionel wrote:
Snip
