- Feb 24, 2010
During this years Morocco trip the indicators developed a weird 'thing'.
When indicating left or right the needle of the voltmeter in the dash dips and rises in time with the flashes, this happens whether the engine is running or not.
Today I noticed that with the ignition on (but not the engine) and the door open, the first 'flash' also makes the key in the ignition alarm (normally heard if the door is opened with the ignition is turned off and key left in) beep on the first flash.... if the door is closed it doesn't do this.
Interestingly the hazard flashers don't do any of the above and work normally.
Before I go in with the tools, anyone come across this before and know where I should be looking/poking?
