Thats true, simple motor for a simple guyPaul said:It was disconected on mine but must have only recently come off as the terminals were very clean. Might be something to do with the egr as yours doesnt have that either![]()
Why do you say this, Les??Ecky Thump said:I also wonder about an intercooler possibly robbing engine life in the long runas I intend on keeping mine for some time yet.
EGT aside, Would the added torque and power not put extra strain on the components? BeBs etc?Andrew Prince said:Why do you say this, Les??An intercooler will increase engine life as it makes the EGTs a bit lower and makes the engine operate more efficiently. Radically upping the fuelling is what may reduce engine life - if done in conjunction with an intercooler being fitted, increasing fuelling within sensible reason shouldn't have much impact on the engine life. All else being equal, adding an intercooler should increase engine life.
Cheers,
Why do you say this, Les??Andrew Prince said:[quote="Ecky Thump":14vyobdn]I also wonder about an intercooler possibly robbing engine life in the long runas I intend on keeping mine for some time yet.
Paul said:How similar is the 80 lump to the 100 lump? Do they have an intercooler as standard even though controlled by an ECU?
