I have a Clarke 500ml oil suction pump which i got from machine mart and it is useless. After using it 2 or 3 times it started leaking oil from every part
. I would say that i takes extra effort to design it in such a way that it simultaneously leaks fluid from every part of the gun (including parts where there should be negative pressure!). I would like to get an oil suction pump that actually works, does anyone have one? If so what brand?
I know there are other solutions out there for filling your diffs and gearboxes but i would like to have a oil suction gun as it small/light, its easy to use and if it works it is not messy.
