BobMurphy
- Mar 1, 2010
The '100' has been sitting, unused, in the yard while we were (are) in lockdown and I finally fired it up to go and collect a set of ramps from a neighbour.
The AHC light was flashing "OFF', which I hadn't seen before, so I checked & cleaned the connections around the pump - no change.
To cut a long story short, the upper balljoint on the N/S height sensor arm had popped off its ball - the rust had got to it .
I have ordered replacement link arms from Milners, but in the meantime used SS locking wire to hold the joints together - I did both fronts just to be on the safe side:
This is the O/S one that was still clinging on (I forgot to take pictures when doing the N/S).
The next challenge will be unbolting the arm from the rheostat - there isn't much left of the nut & thread apart from rust.
A test run showed that the system is working again - great relief.
I also had the Air-con system drained professionally today - the compressor has seized solid (the belt burned through and disappeared - daughters aren't very sensitive to machinery). Now to find a suitable replacement without paying Toyota prices (c. £1200 for the pump and c. £700 for the electric clutch ).
Finally, the inner N/S bracket that holds the rear mudflap had rotted through so I went to fit the nice new Toyota one Simon sent me . . . . .
I now have a shovel-full of rust and a large hole where the lower wheel arch used to be - Ho-Hum.
Tomorrow's job is to fabricate new body panels out of 1.6mm galvanised steel sheet and try to re-hang the mudflap.
Gotta love Scottish cars - they rot before your eyes.
Bob.
Bob.
