this is an interesting thread as now you mention it i get that when i open my fuel cap..i replaced the original fuel cap with a lockable type for added safety on my trips to africa. although ive noticed no ill effects was this a mistake??
ive started getting a slight uneveness at slow revs which disappear as i drive through..ive been thinking fuel starvation perhaps i should change the fuel cap back! any thoughts??
do you think these walbro pumps are a good investment??
Im off to europe for a couple of months and then when i return ill start getting ready for patagonia to alaska so even i will have to start thinking mechanical things!!!
regrads
jeff> From: [Email address removed]> To: [Email address removed]> Subject: Re: [ELCO] again> Date: Tue, 6 May 2008 22:43:26 +0100> > Hi> Not sure if it helps but i had an 'intermittent problem when i first got my > 80. I thought it was the fuel pump as the previous owner said he had gone > through the fuel system., but he had missed the tank. To make sure get the > back seats out and you can get into the tank and clean the crud from the > pick up tube. Solved mine but the symptoms were not exactly the same...> I thought the 80 had a 'get me home' safety system that's to do with the AT > box if there is a fault ? When mine was rebuilt it got stuck in this mode > and it was a single broken wire.. not exactly an engine management but a > safety system of some kind ?!> Cheers> Gareth> ----- Original Message ----- > From: "Benoit Bernard" <[Email address removed]>> To: <[Email address removed]>> Sent: Tuesday, May 06, 2008 8:56 PM> Subject: Re: [ELCO] again> > > >I always get that wooshing noisse when I open my cap! But my 80 she> > run like a cheetah, no problem. But my idle is always change. Does> > this Walmart pusher pump come from USA or EU?> >> > 2008/5/5 Julian A.R. Voelcker <[Email address removed]>:> >> Yes, that's the case with 80s and I think also 90s like yours.> >>> >> One of the problems with brimming your tank is that it can lead to the > >> vent in the filler cap getting gummed up.> >>> >> If you hear a whooshing sound when you remove the filler cap the chances > >> are that the cap is a bit gummed up. If you are careful and watch the > >> spring it is possible to strip the cap down, clean it out, etc. When you > >> do it you can use one of the silicone based dry lube products to > >> lubricate the valve so it opens more easily.> >>> >> If you are getting the whooshing noise it is worth sorting out because it > >> puts more pressure on your injection pump and can lead to fuel starvation > >> at higher revs (80s struggle with this anyway, but you can counter that > >> by fitting a Walbro pusher pump).> >>> >>> >> Regards,> >>> >> Julian Voelcker> >> 07971 540362> >> [Email address removed]--> >> European Land Cruiser Owners Mailing List> >> Further Info: http://www.landcruisers.info/lists/> >>> > --> > European Land Cruiser Owners Mailing List> > Further Info: http://www.landcruisers.info/lists/> > > > --> European Land Cruiser Owners Mailing List> Further Info: http://www.landcruisers.info/lists/
All new Live Search at Live.com
http://clk.atdmt.com/UKM/go/msnnkmgl0010000006ukm/direct/01/
regrads
