Window auto-down stop not working
cmcmill01
Folks,
When I hit the auto down button on the driver side window it goes down but then it sounds like the motor does not stop and so hear a grinding/clicking noise.
Any ideas on the fix? Is there a switch that stops the motor when the window has reached the correct position?
There’s no switch, I think it just senses motor current and stops. If there’s a clicking it’s likely there are some problems with the gears.
You should be able to cancel it by blipping the switch in the up direction.
Yep can stop it by hitting the switch again, is it a sign of a faulty motor?
Might be more the fault of the switch but if you’ve got noises from the motor it’s unlikely to be good.
