Tsavo
- Oct 8, 2019
Hello fellow 70 series owners!
A few weeks back I had my mechanic replace my old and embarrassingly weak coil springs with new Iron Man 50mm lift 'performance' springs all round. Yesterday I fitted new longer, rear shocks to match the new coils. While I was under the vehicle I noticed (see photos - damn hard to get good shots of the springs!) that the springs are sat slightly bowed/arched. The rear pair arch backwards towards the rear and the front pair arch outwards towards the side of the vehicle.
I was of the understanding that a 50mm/2" lift does not require any suspension geometry correction but in my (inexperienced) mind these bowed springs may suggest otherwise. The arch is not severe and the vehicle still handles ok but I can't imagine driving on Kenya's bumpy corrugated roads with bent springs will be a good idea in the long run.
I might guess that the trailing arms are now 'short', the leading arms need castor correction and the front panhard rod/lateral control arm is also 'short'. Can anyone advise if I'm on the right track here? Can I resolve this with offset bushes?
Kenyan small-town mechanics rarely have any experience with modified 4x4's - if any of you 70 series wizards out there could help I'd be chuffed!
Thanks - Ewan
PS it's a LJ79 (3L engine), 235/85 R16 tyres, pretty much stock other than suspension and roof mods.
PPS I bought the vehicle with those horrible Dunlop tyres - don't judge!
Thanks - Ewan
