Short version: I’ll be moving to a new server / host over the weekend and all should be better.
Long version: Yup, I’ve been having a fun time with the support guys and account “managers” with this over the last few weeks. Starting to think they really are a bunch of monkeys. I’m sure I invented some new swear words when one guy said to me “well, have you tried rebooting it”
New server is up and running now so I’ll start the move tonight or tomorrow. The only downtime you should see is while I disable the board to do a backup of the DB and move that over. This should be about 10 minutes or so and you’ll see a message while this is happening.
Once the move has been done you’ll be able to use it as normal. There should be no issue with the domain propagation – those who are slow to update will just be using the old site while those which are quicker will move across sooner. The content will stay the same though regardless of which version you are using.
At worst though you should all move across after 8 hours (I think that is the TTL)
What’s been happening:
Basically, I’m being nailed by cnuts from the over yonder (looks towards Graham’s neighbours) and they crippling the server when they do it. Load averages sitting around 23.0 20.0 25.0 (15 minute intervals) when they’re “at it” While it is happening everything stops working. The firewall on the package I was one was a software server based so while it protected the server, it was crippling the server. New option has a separate one.
It’s been a real pain in the arse as other sites I have on the server which actually make me money are not working. Here’s hoping this will all go away now…
I’ll stick a banner up before I start the process.
CP
