BobMurphy
- Mar 1, 2010
Any bodywork specialists out there ??
I'm in the process of hacking out the rusty remains of my inner sills and have a pair of Toyota panels waiting to be welded in - if I can find something to weld them to.
Has anyone done this before ???
I ask because I'm wondering if the easiest way to replace them is to cut the rocker panel (door sill ?) away from the outside - thus allowing the interior (with its shiny grey steel panels) to be seen and got at.
If I can remove the inner sill from inside I'll have a better chance of getting the whole panel in, instead of cutting and using the lower section only. I'll also have much better access for the MIG torch (I also have TIG, but think MIG is the way to go).
If I get this horribly wrong the truck could be heading for the breakers, the rust is pretty extensive.
Bodywork is not my thing so any advice will be welcome.
As usual, when I've finished I'll know what I should have done from the start .
Bob.
Bob.
