100 Series Remote central locking
Datto
Hi everyone,
I am hoping someone here can help me with this problem.
My local Toyota dealer told me it is normal but other cruisers I have looked at work great.
My remotes are brand new but will only work when i hold them at the bottom of the front windscreen.
I have tried extending the black aerial wire on control box but still the same.
Any help would be great as my wife is going insane.
She just wants to be able to open it from behind the car when she has the kids and shopping.
Thanks.
uHu
norway
Should work well from 50 feet. Did you change the battery in the remote?
Does it work better in some locations? Some communication equipment will interfere with the signal, eg. automatic doors (shops), remote control for trucks, cranes, concrete trucks.
Datto
Makes no difference where the car is. Home, shops anywhere.
New batteries put in both remotes.
I tried on another 100 series and they worked great from over 5 meters behind it.
Have thought of replacing it with after market unit but shouldn't have to. It should work same as others.
Datto
Replaced batteries with same as original even though both remotes were new. Not sure of brand will check.
Will also try holding remote under chin.
Hell I'd try anything at the moment.
Aerial is above glovebox area but when I pulled it out and towards floor still needed remote in centre of windscreen lower area to work.
Datto
Bought a new module and remotes from Toyota for only $100.
Plugged it in and works great.
Happy wife, Happy life :)
