I have a nearly new (6 month old) 110Ah Leisure Battery - Numax XV31MF CXV, dimensions are 330mm length, 172mm width and 242mm height. Used for a solar project and now surplus to requirements. Looking for £50 and can bring to Lincomb if that helps.
Ok £50 and a beer sound better i have tusker from kenya so worth at least the same again.
thanks 3 batteries that is now. could power anything this weekend.
Trevor, that's a shocker. Couldn't you take the lead and post it given the current climate; that's the acid test? Mind you, there's ample opportunity to hand it over on a plate really then he can take it ohm..
Chris, I refuse to take that post seriously. You don't know how to conduct yourself, must have been down the pub as I heard your missus ask you wire you insulate?
Agreed. Sort of lost its fizz. Usually more people gassing away. We need to just distil why that might be. Perhaps they just need to vent something. Maybe blow their lid. On the level of course and up to the mark with a degree of gravity about the specifics
