Hi folks I need a little bit of a hand adjusting my valves and would like a bit of a walk through or conformation. As per manual I find tdc by rotating crank to the compression stroke so both valves are loose on number one and mark aligned on crank pulley, then adjust clearances as per manual . In the manual it describes placing a mark every 120 degrees so there are essentially 3 marks including factory mark and by rotating the engine as per mark you will find tdc of each piston from 1 to 6 . Just to get my head around this that would mean the crank needs to rotate 360 degrees twice ? Any other advice would be greatly appreciated.
