1kzte tuning/tuning chip?
intercooledkzj95
canada
Hey there!
Looking for some opinions on tuning the 1kz engine.
I read this article: Welcome to Land Cruiser Owners On Line - [Leaving Land Cruiser Club] which was quite informative, but it does not suggest which chip meets their criteria of a good chip.
Does someone here have any advice? Or further reading?
As discussed in the above article, I am mostly interested in something that will not only give a bit more go in lower RPM's, but is also beneficial in terms of overall engine durability and fuel economy; via fuel mapping and independent injection timing.
Much appreciation for any help!
Have a look on the Ozbush web site.
I know someone with a unit on their 1kd engine, who has good results with all those requirements of yours. You are able to manually alter settings on the unit, and easy to install.
Don't know if they do one for the 1kz though.
Tractionman, that is exactly the type of device the article on lcool warns against using.
I do appreciate the reply!
Ok mate. Any reason why they advise against it ?
The one I know of on a 1kd engine has been in use for some years with no problems.
I think with all of these mappers you have to be sensible with settings or expect trouble.
By no means am I the expert, I just read an article haha. That said, It is advised against because it is essentially just adding more (or less) fuel at the touch of a dial without consideration for RPM differences, throttle position, or injection timing. From what I saw on the ozbush website, it is essentially like having the injection pump set screw easily accessible on your dash, which adds more or less fuel across the board. A more complex chip, as I understand it, takes into account the aforementioned to produce power and torque in the low RPM range, along with safety features in line with the ECU to prevent the vehicle from overdoing it.
Im still not convinced a chip is a good idea in any regard when taking engine longevity into consideration, I am simply poking about to see what is out there.
Thanks for reply. Who did the advising - a competitor ? Lol.
I'm sure that all those points and more were taken into consideration by an ex member, a real expert/guru on 120's.
He is very much respected by those who know him, for his vast knowledge/workings/sensible mods, and well being of the 1kdv engines. I'll check it out next time I speak with him.
Interestingly, on the lcool website there was no advertising, there was no mention of any chip brands whatsoever. It just laid out information based on technical information and testing. It suggested doing ones own research into which chips suit the provided information. Which is why I am now asking questions in forums.
I am actually running the 1kz-te, but I would appreciate the knowledge of a "guru" anyhow.
Cheers mate.
If its good enough for the guru's 120 its good enough for mine. I second the fact that his knowledge on these engines is second to none
Whilst I appreciate your engine is the 1kz-te, what I tried to get across and perhaps explained badly, is that everything Tony does is well thought out and trialled. Nothing is/are whims or boy racer bolt ons, and everything taken into account, so the Ozbush mapper he has used for several/many years, will have been done with every consideration as necessary with points raised by yourself along with other simple engine mods.
Reliability and economy at the forefront, no point it introducing something that will give loads of power, guzzle diesel and blow the engine.
