Knucklehead
- May 28, 2013
Hi all,
Now starting to understand why folk changed over to 12v starter systems.
Hoping somebody on here can give me some more things to try for my 80 that is not cranking before I have to admit defeat and get it recovered to a garage for the first time.
Turn the key and get the loud clack clack clack from the starter. No sign of engine turning.
So far I've had fresh batteries load tested just in case, fitted new starter motor, tested Starter Relay and 12/24v voltage relay as per FSM, took Starter Relay apart just in case but looks like new inside, checked all connections are clean and tight. Still nowt.
I did notice however when turning the key the voltmeter inside goes from its normal just over half way at rest to near zero when I crank the key. Fairly sure it barely dropped when starting before this all happened.
I had wondered if I could take the 2 batteries out of the vehicle, connect them together using jump leads giving 24v, use third battery to apply 12v to the small Starter spade terminal 50 and then touch the 24v directly to the Starter terminal 30 that the battery cable normally attaches to?
Not being too great with electrical stuff not sure if it's a good idea to try and directly crank the starter motor this way or maybe i'll electrocute my ass.
Any thoughts how to further trouble shoot would be much appreciated. Hate not being to fix stuff myself.
Cheers,
Dave.
Cheers,
Dave.
