2nd gear
Hi guys
does anyone knows if the 2ng gear problem on the manual gearbox is a factory
problem or cause due to heavy loading?
I think if I buy overhaul gearbox will that problem with the 2nd gear
disappear
cheers
Lubo
HDJ80 '96mod
Lubo
It's a gearbox originally designed for a bus, and they come from the
factory with a stiff 2nd gear.
They vary a lot: mine (at 149k miles) is a bit awkward, especially in
cold weather, for the first mile or two, but after that it is fine; but
some others struggle to change gear at all when it is cold. Mine has
got no better or worse in the 7 years / 90k miles I've had the car, so I
think driving style (or more precisely gear changing style) probably
matters a lot. I'm very gentle with gearboxes generally, and happy to
double de-clutch when changing down if necessary.
On the basis that mine is perfectly acceptable, then a new or
reconditioned box is going to be as good or better. I remember reading
comments by Herb Peyerl, a very competent Canadian mechanic on the
80sCool list, that rebuilding his box still left 2nd gear as awkward,
but quite usable - it sounded pretty much like mine is now.
There are some other things you can do: the manual with my car says that
you should use 75w90 oil in the box, and Australian users have reported
that Castrol VMX-M can make a stiff box a lot better, so maybe you could
try that. However I imagine it's a lot colder that Australia where you
are so, on the basis that the difference between "cold" and "warm" makes
such a difference to my box, you could perhaps try xxwyy oil, where "xx"
is some number around 65, and "yy" around 80. I don't know what is
available in Norway, but in my experience a farm / tractor workshop is
the place to ask those sorts of questions since they will be used to
dealing with lots of different machines.
Finally, knowing your high opinion of Norwegian mechanics (!), there is
a workshop about 15 miles away from me here in Devon that is probably
the best place in the UK to get a gearbox rebuilt. I don't know if that
would interest you, but I have more information if you want it.
Christopher Bell
Devon UK
1996 1HD-F
Hi guys
factory problem or cause due to heavy loading?
disappear
cheers
Lubo
HDJ80 '96mod
Christopher
that explain it all:when it comes with a stiff 2nd gear from the factory
there isn't much to do about it after...
I have absolute the same problem as you and it never bothered me at
summer...only at cold winter days and as you some km and it's gone...or let
say from 10 tries makes 2-3 problems
It looks like I have to live with that ...
I'll try that oil you recommended when I change the timing belt and see how
it will behave then...
thanks for you answer:very kind of you
Lubo
PS:as for the guys in Devon rebuilding the gearboxes....well...don't
know...a guy in Belgium sells rebuild gearbox(0km) for around 1800euro incl.
VAT
On Mon, Sep 8, 2008 at 10:34 AM, Christopher Bell <[Email address removed]
> wrote:
> Lubo
> Christopher Bell
> Devon UK
> 1996 1HD-F
> Hi guys
> disappear
> cheers
> Lubo
> HDJ80 '96mod
> European Land Cruiser Owners Mailing List
> Further Info: http://www.landcruisers.info/lists/
Hi Christopher
I'm now back at work - so back on the e-mail and passing the days...
Re
Do they do auto gear boxes also? Mine is buggered.
Thannks
Niall
HDJ80
Niall
Yes. It's the Exeter Gearbox Centre and their phone number is 01392
250225.
You could ask them about a swap to a manual, but I would have thought
that it would only be economic if you could find a donor vehicle that
has been in a crash from which to lift all the gubbins.
CB
Following on from this recommendation I phoned Exeter Gearbox Centre to
arrange to have my gearbox reconditioned. All was well on the phone and I
arranged to leave my car there Sunday evening after the ELCO Weekend.
I received a phone call from them today saying they are not going to do any
work on my car because it is "an extreme, one off, modified competition
vehicle". I pointed out to them that is a road legal MOTed car with big
tyres, lifted suspension and a few dents. After much discussion, including
me offering to give up the warranty, they still refused to do any work on my
car.
Basically I have wasted a 300 mile round trip to use this company. If your
car is completely standard then I am sure they offer a good service,
however, if you have modified your car don't waste your time with them.
Sorry if this sounds like a bit of a rant, it's not, I'm just annoyed at
them for not metioning they don't work on modified cars on the phone.
Ian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On 22 Sep 2008, at 21:00, Lubomir Kolev wrote:
Hi Lubo,
I must have missed your original post - could you describe what's
happening 'from the top'?
Neill Watson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,
Are you getting a continual judder when pulling off or is it a one off event when the slack is being taken up in the driveline or is it continuous for a few seconds?
If the splines and UJs on the prop shaft are worn and the diffs are getting tired, you will get some judder as the slack is taken up - this is very common on 80s.
Julian
Email: [Email address removed]
Tel:=A0+44 (0)845 508 6863
Ian
I feel really guilty having recommended them - sorry for your wasted
journey.
I can only say that they did well on my - unmodified - car.
Christopher Bell
| your
them.
at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Jon
No I haven't. Exactly what and where am I looking for? And how hard
are they to replace?
CB
| Have you checked that your engine and gearbox mounts are in one piece
| still? I replaced a passenger side engine mounting a couple of years
ago
| because a vibration in reverse turned out to be an unbonded mounting
| letting the engine move. When I had my gearbox out last year the
gearbox
| mountings were also unbonded.
| Jon.
Good point, I had the same problem on a car but why only second gear and
when cold? Might be worth checking if the effect is present in both high
and low? Could still be mounts as the loadings from standstill in first and
second are different.
Malcolm
Stafford (UK)
FJ45 '75 & FJ45 '76
Julian
it seems to be only at the beginning,otherwise functions very well...about a
year ago I sort of check up the car and got that tech report saying both
diffs were sort of worn out(slack), but that was due to the kilometers and
was nothing wrong actually.the same was said about the 4X4 gearbox so if I
wanted everything to be OK I had to pay A LOT of money,so I had to give up
for that time...also at that time I didn't noticed that kind of
juddering...it was another one-the one you get when taking suddenly you leg
off the gas pedal..
cheers
Lubo
On Tue, Sep 23, 2008 at 9:28 AM, Julian A.R. Voelcker <[Email address removed]
> wrote:
> Lubo,
> for a few seconds?
> common on 80s.
> Regards
> Julian
> Tel: +44 (0)845 508 6863
Jon
don't know anything about it-the single thing I'm good at is to drive the
car to Toyota and let them experience with it...and it is not so bad-already
changed the clutch 3 times and I paid for one ;-)))
Lubo
On Tue, Sep 23, 2008 at 10:53 AM, Jon Wildsmith <[Email address removed]> wrote:
> still? I replaced a passenger side engine mounting a couple of years ago
> letting the engine move. When I had my gearbox out last year the gearbox
> Jon.
Jon
You're a star: I too get the "grinding in reverse" noise when reversing
a trailer uphill in low range - lots of torque on the transmission - so
hopefully it's that.
I'll get them to check all these when it goes in for its pre-MOT service
next month.
CB
| There's an engine mount either side of the engine, between the engine
and
| the chassis rails. On mine the big block of rubber was no longer
bonded to
| the metal. When reversing up a slope there was a mild grinding noise
as
| the engine would tip up and the side of the sump hit the mounting,
drop
| back down, repeat. The noise wasn't all that loud and I only worked
out
| what was wrong when I happened to notice markings on the side of the
sump!
| (it had always made this noise). I put a jack under the sump with a
block
| of wood and jacked the engine up a little and sure enough one side had
a
| gap. It was a bit of a fiddle to get enough clearance to get the old
out
| and new in but not too bad.
| The gearbox mounting is between the gearbox and the gearbox
crossmember.
| Again on mine the rubber blocks were no longer bonded to the metal.
Put a
| jack under the gearbox and either raise the jack a little or undo the
8
| cross member chassis bolts 20mm or so each to lower the cross member.
The
| gearbox and cross member should be stuck to each other if your
mountings
| are ok. If the gearbox and cross member move appart then your mounting
is
| probably no longer bonded.
| I don't know if this is common but I thought it was worth a mention
| because it's the kind of thing I'd check.
| Jon.
