- May 20, 2010
No vehicle mods to run on bio. You can just run straight if your fuel is good enough
What tyres do you have tp?Just fill the tank to the top of the filler neck each time and note the milage between fill ups.
In the absence of fancy electronics and onboard computers it's probably the most accurate way of measuring MPG.
Fuel is a known measurement but the mileage is the dependant on accuracy of the speedo so if standard it could be 10% out in over reading so would make 30mpg only 27mpg, just a thought lol
