Ok folks it's update time again.
Just picked up the prototype pair today. Attached a pair of hinges and a seal each and they don't look half bad in the buff!
View attachment 112784 View attachment 112786
Now these are going to be trial fitted into my truck to make sure everything is right. If I need to make any adjustments I can do otherwise it's full steam ahead to produce the remainder of the batch. I've got to rough 'em up a bit before they get painted as I forgot this small request when they were all in the flat.
One change I have made is to go for a slightly different more readily available grade of aluminium. Two benefits apart from availability are its resistance to salt, not that it should ever see any, as it's what they build boats from. Plus it is also very difficult to bend and get to stay there. The fabricator literally put a door under his knee against the floor and put a 120 bend in it and it sprang back to exactly where it was before he bent it. I could hardly believe it. So, what this means is on top of the thoughts I have already had on making these as secure as possible against casual theft, this material now means it is more difficult to get in the gullwings than it is the rest of the vehicle. Happy days!
