80 series rear bearing adjustment tool
I didn't expect to find much when needed to adjust my rear bearing, hub had axle oil in but not leaking out of the hub. Not a high miler either. Other side was fine though.
Bearings in really good condition. Cleaned and re packed. OK so why not put new bearings in whilst in there? Well, time really and timing. I shall be doing a full overhaul on the back end at some point, mostly around the brakes and I may be pulling the axles again at some point. Changed the inner axle seal although it wasn't bad. The lip had worn away to a degree and this was letting a little oil weep through. The new tool was good but just needs a few mins on the lathe to thin it down a little in places.
