- Mar 1, 2010
Hi
If you look at "AES" website under battery master switch you will see Lucas SSB111. This is the one I used. 250 amps continuous or 2500 amps for 5 secs !! I bolted mine to the top of the fuel filter just using one hole. It is designed, however, so that nose of the switch goes through a hole you have cut in the bulkhead so that the key is in the car and the wiring the other side. I could not see an easy way with mine. What do you think?
Frank
Frank
