chadr
There was a recent post on the "other" side about front ball joint wear on the Colorado which caused me some concern.....Bob Murphy, who is very knowledgeable member (and also a member here I believe) posted pics of a failure on his 1997 3.0TD 95 which had done around 133K.
I hope Bob won't mind if I copy his posts and pics here;
Is there an easy way to check for wear? Or should we be replacing these as part of "routine" maintenance after a certain mileage/age anyway?
I've got visions of mine failing at the worst possible moment......
You are right about problems with the lower balljoints.
I was towing two large horses with four adults and loads of kit in the car when the steering started to feel stiff. I said I though there was a problem and would look for a layby.
Well, I didn't make it . . . . BANG . . Clatter . . Scraaaaaaaaape.
I ended-up changing top and bottom ball joints on both sides, new springs & shocks, wheel bearings, Brake hoses, Track Rod ends an ABS harness and a replacement N/S drive shaft - about £1,000 all-up.
The top ball joints are a bit of a pain as they are tight and the steering knuckle is 'springy' so it doesn't knock out well.
I have a 30-ton floor press - its a doddle with one of those (so are the wheel bearings).
Looking at the mechanics, there is a tremendous force trying to pull the lower balljoint apart. Its something that we should be replacing on a regular basis in my opinion (Isn't hindsight wonderful - if you could bottle it you'd make a fortune).![]()
I used Milners parts (Roughtrax springs) but I didn't find them to be good - rather soft, nothing torqued-up cleanly and it all felt as though it was bending/stretching. I have paint-marked all the important joints and check them regularly.
I would go for better quality stuff if you can.
Good luck.![]()
Bob.
I was doing about 41 mph when it happened.
The wheel (actually the tyre) took the load but it was quite civilised and controllable. I didn't have brakes though as the N/S hose had gone (strange that, I should have had rear brakes as its a dual circuit system - but I couldn't feel any - I used the handbrake).
The lower balljoint stud and nut were worn away on the road, as was one of the tripod bearings on the driveshaft.
There wasn't any damage to the road - just a feint line on the stone in the tarmac.
It cost me a new BFG A/T as the tyre sidewall was worn through to the carcass.![]()
I repaired the plastic trim and mud flap with a hot air gun and a hot glue gun - its holding up OK.
It was a job that I'd been intending to do as a precaution - typical.![]()
The truck had 133,000 miles on it and I doubt the balljoints had ever been changed so . . Don't delay if you have a high mileage Cruiser !!!
Bob.
