cavanmick
- Sep 18, 2013
Hi folks, chap in the garage next to me in work has a a 96 3.0 prado in with a gear fault.
It drives perfectly when its cold and can be fine for up to fifty miles, then it will start not changing up and holding on to the gears for far longer than usual, it will change up eventually but sometimes you have to plant the boot to get the box to change the gear, its had the oil changed twice so far but has made no difference.
Anyone on here come accross similar.
Thanks a mill.
Thanks a mill.
