Bert
- Feb 11, 2016
I apologise if this has been discussed in a previous thread but I couldn’t find one like this while searching through the forums last night. Ok folks, I’ll try and describe exactly what I did before everything went south. After driving home in my automatic ’97 Prado, and at the bottom of the access road to my house, I thought that I’d engage the ‘HL’ centre diff lock just to ‘turn it over’ as this was last engaged back in early March when I paid a visit to Julian at Overland Cruisers. So, at the bottom of my lane which is gravel with a slight gradient, I put the shift lever into Neutral (N) and pushed the transfer lever from ‘H’ to ‘HL’. The light on the dashboard came on to let me know that it was engaged. I drove slowly up the lane which is about 100 yards, turned into my back garden and then stopped. I put the transfer lever back into the ‘H’ position, but noticed that the light on the dash stayed on. The confusion started here. Whilst stationary, with the front wheels in line, I moved the transfer lever back into ‘HL’, then back into ‘H’. Still the light remained on informing me that the centre diff lock was still engaged. At this point I moved the transfer lever through all the ranges, ‘HL’, ‘N’ and ‘LL’ then back down to ‘H’; still the light stayed on. At this point I decided to ignore it, leave it in ‘H’, the shift lever in ‘P’, turned off the engine and went in for a cup of tea. A couple of hours later, I got brave again and got back in. Ignition on, engine running with shift lever still in ‘P’ the centre diff light still on with the transfer lever in ‘H’ I decided to drive it back down the lane and around the oval to see if I could shake it loose or something. I reversed out of my garden and I’m sure that there was some ‘knocking’ from the rear axle but can’t be sure. Then I drove back down the lane to the bottom. At this point I had to turn right which was a little tight due to access issues and the knocking or shuddering occurred again. I had to reverse again a little to get by a conveniently parked white van, and then I proceeded to drive around the estate at low speed, and then back up my lane. All the while the diff lock stayed on, even though the transfer lever was in ‘H’. It wasn’t until I got back to my garden that I think I moved it from ‘H’ to ‘HL’ and back to ‘H’ that the light finally went off. Brilliant I thought, though still confused by the whole experience. I thought that it may be down to complete lack of use. Anyway, if you are still awake and reading this, a few days later I tried it again. With the car in ‘N’, I moved the transfer lever from ‘H’ to ‘HL’……. Nothing happened; no faithful little light came on the dashboard. I moved up and down through the range on the transfer lever, still no light came on. So, can anybody tell me what has happened, have I murdered my rear axle somehow? Is it just stuck? All helpful comments greatly appreciated. Cheers. Oh, just a footnote, thinking on it I think the nocking or shuddering only occurred with the transfer lever in ‘HL’ and when the front wheels were turned as I manoeuvred so this fits with the wheels moving at different speeds while turning left or right, so I THINK this is normal???? Please help.
