A big thank you
A quick note to say a big thank you to Julian.
I was on my way to Wales in the cruiser on Good Friday when it started
overheating at anything over 55 mph. Not a show stopper but very annoying.
I was close to Julian's house but did not have his phone number with me. On
the off chance he was in, I called in to see if he had a spare thermostat I
could buy. Well not only was he in, he also had a spare thermostat. How
lucky was I? To my total amazement he then said follow him to the workshop
and he fitted it as well!!
I still have an overheating issue but now it's at 75 not 55. The rad is not
blocked but does have a lot of fins missing. I will replace it and the
water pump to hopefully banish the problem.
So thanks again Julian your help was greatly appreciated.
Ian Rubie
1996 HDJ80
No worries Ian, always happy to help out.
BTW you forgot to mention me crawling around under your car with a cracked rib :)
Julian
Email: [Email address removed]
Mobile:=A0+44 (0)7971 540 362
Julian how did you crack your rub
john 92HDJ 80 1HDT
SNIP
rib :)
Julian
Mobile: +44 (0)7971 540 362
I cracked my rub trying to force a fuel pipe onto a Frontrunner dual
filler neck - it's easy to get the first one on, but the second one is a
complete b**tard - the pipes are too close together.
Anyway, using both hands I was trying to pull the pipe onto the filler
that was wedged against my chest and as I was trying to pull the bl**dy
thing on I heard a crack from one of my ribs.
A week and a bit later it is still pretty painful, although I have found
that extra strong ibuprophen chased down by an extremely large whisky in
the evenings means that at least I get a decent nights sleep ;-)
07971 540362
