Having owned my 2002 v8 for a few months now I've noticed a few things I'd like to change or improve!
1. Is there an induction kit that will give the v8 more low speed acceleration, as in when doing 40 mph or so the engine can be a bit hesitant unless you plant the boot causing the gearbox to drop two gears!!! I'm not looking for a race ready car just a bit more responsive,maybe a kit that can be switched on/off.
2. I think the gearbox is hydraulic but not sure, is it normal for it to be clunky, thumpy when drive is engaged and it first starts to move? Almost like something is slow to engage?
It's ok through the gears but any time it drops a gear it's a bit thumpy!
3. The satnav is pants so I'm going to change it, will a standard double din stereo fit?
And finally I've read up on a second battery install and might do this during the induction kit install. Do I need to use an auto electrician to do this??
Thanks for your time, James
