SimonD
- Mar 15, 2010
If you change your valve body the kit comes with a supplied transmission pan gasket which works well - it is cork from memory. I need to drop my pan again and I can't find a part number for the 80 series auto box gasket. I found 35168-36010 but it seems to be for the A440 box according to ToyoDIY. Simon @ Toyota says there is no gasket - you only need sealant.
My question is, do any of you use a gasket for the auto-pan and if so, who supplies it and what is the part number? If you only use sealant, what is the sealant you use?
