Air con drain
Neil Stone
Evening all
Just a quick question, where should the aircon drain?
Is it the pipe behind the nearside wheel attached to the chassis?
If it's blocked what are the symptoms (had water pissing out from midway down the passenger door today, but I was too slow to see where it actually came from) and what is the procedure for sorting out the blockage?
Any thoughts or suggestions?
Neil
That's the pipe. If it's blocked the passenger will get water in their feet, which will be below the evaporator box. Water from the door will be something else.
