Air suspensions
I am looking for an air suspension like those new Land Rovers, toareg
etc... However I was looking for a kind of upgrade, option kit etc...
for HDJ80 rigid axle coil suspenson. does they existe?
I found this, fhis is not a true one but can I improve the ride?
Confort? Weight?
http://www.drivetrain.com/airliftintro.html
=2E
Esta mensagem e quaisquer ficheiros anexos, podem conter informa=E7=E3o confidencial ou de uso restrito. Se n=E3o for destinat=E1rio desta mensagem, por favor notifique imediatamente o remetente da mesma e proceda =E0 sua destrui=E7=E3o. N=E3o poder=E1 revelar, copiar, distribuir ou de alguma forma usar o seu conte=FAdo. O Banco Finantia, S.A. utiliza software anti v=EDrus. No entanto, n=E3o obstante terem sido tomadas todas as precau=E7=F5es, n=E3o =E9 garantido que a mensagem e seus anexos n=E3o contenham v=EDrus.
This message, including any attachments, may contain confidential information or privileged material. If you are not the intended recipient please notify the sender immediately by e-mail and delete it from your system. You should not disseminate, distribute or copy this e-mail or disclose its content to anyone. We believe, but do not warrant, that this e-mail, including any attachments, is virus free
On 7/5/05, Vitor Costa <[Email address removed]> wrote:
Vitor,
Why? Are coil springs inadequate? For which application in particular?
Rgds,
Roman (London, UK)
'92 HDJ80
Hi Vitor,
There are a few kits around the place but only really useful if you
want to be able to alter the characteristics on the move - you are
probably better off just going for an OME upgrade and making sure that
you have the correct spring/damper combination for the weight your
vehicle is carrying.
My 80 came with a 2.5" heavy duty OME lift which is intended for a
vehicle with a winch and winch bar on the front and long range tank and
tyre carrier on the back - without these it gives a very harsh ride (my
7month pregnant wife hates it!!) - The only time we get the full
benefit is when fully laden going for family holidays.
Mobile: 07971 540362
1994 HDJ80, 2.5" OME Lift
