1992 hdj80 with 190hp...? Intercooler kind gizmo?
Hi all
Can someone explain what this could be?
Pics:
http://bilder.mobile.de/images/autos/515377/11111111172039511-31219-1120
481538_4.bild
This is on a add on mobile.de the url is a bit big:
http://www.mobile.de/cgi-bin/da.pl?sprache=3D2&bereich=3Dpkw&id=3D111111111720
39511&
Esta mensagem e quaisquer ficheiros anexos, podem conter informa=E7=E3o confidencial ou de uso restrito. Se n=E3o for destinat=E1rio desta mensagem, por favor notifique imediatamente o remetente da mesma e proceda =E0 sua destrui=E7=E3o. N=E3o poder=E1 revelar, copiar, distribuir ou de alguma forma usar o seu conte=FAdo. O Banco Finantia, S.A. utiliza software anti v=EDrus. No entanto, n=E3o obstante terem sido tomadas todas as precau=E7=F5es, n=E3o =E9 garantido que a mensagem e seus anexos n=E3o contenham v=EDrus.
This message, including any attachments, may contain confidential information or privileged material. If you are not the intended recipient please notify the sender immediately by e-mail and delete it from your system. You should not disseminate, distribute or copy this e-mail or disclose its content to anyone. We believe, but do not warrant, that this e-mail, including any attachments, is virus free
Hi Vitor,
My guess is that it is a liquid cooled intercooler - you can see the
reservoir in the top left corner and the main unit appears to have
banjo style connectors feeding to the front of the engine bay, probably
to the liquid cooler.
These units are pretty handy where space is limited and you want to
keep the distance of pipework between the turbo and the engine to a
minimum (increasing it can introduce turbo lag).
They would have a liquid cooler in front of the rad, that feeds cool
liquid to the equivalent of a jacketed radiator - the cool liquid drops
the temperature of the air passing through it via the jacket.
The big black thing is most likely the jacket with the core running
between the two connections that you see on top.
Mobile: 07971 540362
1994 HDJ80, 2.5" OME Lift
Hi Vitor
It's a water-air intercooler. It will be plumbed via an electric pump to its
own small radiator probably mounted in front of the main cooling rad.
Some claim these are more efficient than an air to air intercooler but I
suspect its not that simple - size matters etc. They do enable you to keep
the size of the inlet tract down so theoretically should give a slightly
quicker response to the turbo (less volume of air to pressurise) but I think
this is unlikely to make any difference on a turbo diesel with no throttle
plate.
As far as I can see the main advantage is that you only need to find room
for the water pipes when plumbing through to the front of the vehicle.
Hope this helps.
Toby
1990 HDJ80 UK
-----Original Message-----
Behalf Of Vitor Costa
Sent: 05 July 2005 10:37
To: [Email address removed]
Subject: [ELCO] 1992 hdj80 with 190hp...? Intercooler kind gizmo?
Hi all
Pics:
481538_4.bild
___________________________________________________________
How much free photo storage do you get? Store your holiday
snaps for FREE with Yahoo! Photos http://uk.photos.yahoo.com
Hi Julian, Toby and all
I suspected already, but seeing the tipe of pipes used on it and translating on google the description "...190 HP air conditioning system," could it be a AC type system to cool de air?
