When summer finally arrived I realised that my aircon has stopped working, so took it down to my local garage for a recharge and it appears its a little more involved... Firstly the system was Empty (a 'full recovery process' retrieved absolutely ziltch) and my system is R12 (its a '93, so about the time systems moved over to R134a).
So they've recommended I consider changing over to R134a as they believe, considering its age, they'd be doing the majority of work required anyway and a refill using a R12 compatible gas costs much more...
They recommend changing over the o-rings, compressor seals, schrader? valves, expansion valves and dryer along with a full flush of all the pipework prior to a nitrogen purge to check the system (including the only parts not 'meddled' with - condenser / evaporator) - so all in all the complete system then! They declined to give me a fixed price to do the whole lot but said it'll be 'considerable'
- although by that point I'd pretty much decided to come away and do some homework/searching...
I agree that replacing all the o-rings in a 20 yr old truck sounds sensible and I was expecting to replace dryer and other 'minor items' but is the full conversion a good idea?
I've read a couple of detailed write ups which cover replacement of major components - and this does look doable - so considering the system is already empty, should I consider completing the majority of any work required myself?? I was thinking, with a little guidance, I could strip down, clean / flush and replace all seals/major parts and get the experts to purge/test prior to adding refrigerant... So what say you all???
