Hi there. Sorry if this is a bit abstract!
So. I've been slowly fixing a very low km UK 12V 80 series - rust and body work is exhausting, and particularly without a garage.
I've attached two images. One is the tailgate hinge. The metal around the left hinge assay has cracked (pic might be a bit too close sorry!). It doesn't appear to be rust related - so presumably a weld will do - but I wonder if anyone else has had this issue and if this is common in 80s - and more importantly if I weld this will this create some unintended issues, or if there is anything else I should look to do!?
The second is rust. I proudly replaced my rusted upper tailgate with a rust free version. But rather counter-productive to the entire operation was rust in the body that I hadn't yet seen [thanks to 4 inch lift]- the lower picture is the upper part of the backdoor weather strip - so rear center of the roof. Its the last place I expected rust after all my reading! Maybe it is my fat fingers not being very articulated with online searches, but are these typical problem spots....very happy to be corrected/informed.
