auto box and a"fuse" !!! help.....
This was mine
HavLandcruiser004-1.jpge you got the ECT button on the dash just above the radio in the pic ?
I was thinking the other way round mate. This trucks a strange one. Could be on the changeover year and Toyota used bits from the earlier truck and bits from the later. Every 442 box I've come across has the overdrive button. I have a truck in at the min though that may be similar to yours. Ill have a look at it before lincomb. Ill check the numbers on it etc. I know it doesn't have the overdrive but it had the throttle position sensor on the pump. Thought that was strange. Ill do some digging mate
Excellent, thank you very much, I was thinking something along them lines, my truck is out of the parts bin lol
Sooty about my delays in answering, laptop has gone down(again) do using my phone now !!!
:icon-biggrin:
So did i Dean, alas I'm cruiser less at the moment. a fellow member on here is enjoying it now.
If you have cruise control(?) your early A442F box will have a solenoid for OD which the CC ECU can use to turn off OD when it needs to. Otherwise, as Dave mentioned, there are things you can fiddle with on the valve body but they are all hydraulic apart from the CC OD solenoid if it has CC.
RM314E & RM315E document the later version of the A442F with the ECU controlled valve body not the earlier hydraulic valve body version.
The A440F wasn't fitted to 80's with the 1HD-T.
