Axle locker sensor
Hi all,
I have a lock position sensor that seems to be playing up, so I needs
to replaced soon.
Is the front and rear sensor identical or do they have different part numbers?
Rgds,
Roman (London, UK)
'92 HDJ80 with factory lockers
Hi Roman,
Once I have loaded the EPC onto my new machine I'll check it out for you.
Mobile: 07971 540362
Skype: julianvoelcker
1994 HDJ80, 2.5" OME Lift
Thanks, Julian.
I've looked up the EPC and they are called switches, not sensors, but
I still have too litle information to decide if I need to order one or
both for spares.
Rgds,
Roman (London, UK)
'92 HDJ80
On 11/23/06, Julian Voelcker <[Email address removed]> wrote:
Hi Roman,
Any difference in part numbers.
They should be the same since they only have a basic functiion, however
they may vary depending on where they are on the actuators - your
quickest bet is to take them off and see if you can swap them around - it
will give you a good chance to get under and check all the contacts etc.
