Totally agree with all of that.The problem will vehicle fires is the battery is quite happy to keep throwing out hundreds of amps through shorted cables, once cable insulation has melted, an extinguished fire is almost certainly going to reignite, so shutting off the current at the battery or batteries is the first priority, this being my justification for fuses at the actual terminals.
Often by the time the bonnet has been opened (assuming you still can) and the batteries disconnected, the damage is already done and your vehicle may be a write off, fuses are quick and decisive IMO.
Whilst on the subject, given engines and gearboxes and so forth are isolated from the body to offer insulation from vibration ect, the main path for earth is the heavy cable from engine to body or battery. The importance of this cable must never be underestimated, without it the earth return is going to be via a throttle or bonnet release cable.
Regards
One thing, if you get a short on something smaller than your main starter cables it’s fused or fitted with a fusible link, so we can make reasonable assumptions that the fuse or fusible link will blow, yes?
What about if a 10A skinny earth wire going to an earth point or even the negative terminal of the battery, gets shorted across to a heavier fused cable?
Also, (ok, two things ) how do you know that fuse you’ve fitted will actually blow in the event the starter cabling is damaged?
