bearings
Hi Guys
I was just wondering if the front and rear wheel bearings are the same.
If the rear ones were put in the front would it be OK.
Ok I know someone will ask so this is why I ask.
I left the cruiser into Toy to get the steering damper and REAR wheel
bearings fitted and brakes bleed..
Well guess what, they fitted the bearings alright but to the front axel
instead of the rear.
They are going to put it right by fitting new bearing to the rear but seeing
as how I intended for them to fit the rear bearings to the rear and not the
front, WILL THEY DO.
Maybe I need an exorcism on the cruiser at this stage
cheers
john still jynxed 92HDJ 80 1HDT
John,
'I was just wondering if the front and rear wheel bearings are the same.'
IIRC early 80 series the front and rear wheel bearings are the same, however
at some stage I think that changed. Someone who has the EPC in front of them
should be able to tell you. If they managed to fit them to the front ok I
would think they'll be fine.
Best of luck,
Toby
1990 HDJ80 UK
___________________________________________________________
Try the all-new Yahoo! Mail. "The New Version is radically easier to use" ? The Wall Street Journal
http://uk.docs.yahoo.com/nowyoucan.html
