beep
Hi everybody out there
yesterday i drove my LC and suddenly came a beep like a drill machine from
the front left on the dashboard...when I blink to the left or right it
disappears,but again came after driving forward.stop the engine-again the
same beep-very annoying if you ask me...after a while disappear for good.I
know it will come back again soon or later...any ideas what might be?no
warning lights ...nothing at all to show me there is something wrong ...
cheers
lubo
LC HDJ80,'96 mod,24 valves,275tkm
Hi,
Tow bar attachment wet?
I have something similar on mine expect mine is the opposite, occasionally
(usually after jet washing or wading deep ;-) ) when I indicate left and
right I get a bleeping coming from the back at the rear.
Still not figured it out yet, I do have a laptop installed in the back
(drivers side where the beeping is coming from) although it only does it
when my tow bar(the plug) gets wet I believe.
Not had a chance to track it down yet as it stops usually quite quickly and
then won't appear again for months and have not been too worried, I am
guessing mine is the tow bar plug getting wet, sound like a huge lorry when
they are in reverse. Beep,pause, Beep,pause Beep but in time with the
flashing of the indicators.
Don't even know if mine is an aftermarket tow bar or a Toy one as it was on
the vehicle when I purchased it. Mines a 70 series as well so not an 80.
Is the beep the same sort of tone as the beeper that reminds you when you
leave the lights on?
Hope it helps?
Martin Naylor.
That's what I am thinking Martin. Either the lights on, or the door open
beeper shorting out.
Clive Marks
Home: +44 1293 514600
Mobile: +44 7821 491897
Crawley, West Sussex, UK.
Yeah great mind's think a like ;-).
Without hijacking this thread, my beep is a bit weirder as I don't have the
laptop on when mine does it and its certainly coming from the driver's side
at the rear of the vehicle.
I am thinking its fitted with an aftermarket beeper(somewhere) that is
shorting out on the reverse tow bar attachment(when wet) if that makes
sense. Unless it is coming through the laptop somehow.
Weird eh, but Lubo's problem seems more annoying.
Martin.
Behalf Of Clive Marks
Sent: 13 August 2008 17:12
To: [Email address removed]
Subject: Re: [ELCO] beep
Clive Marks
Martin,
Reversing beeper?
Clive Marks
Hi Clive,
Yeah I guess, but it must only comea on when the tow bar plug is plugged in.
I don't tow anything and never had, so I will remove the wiring loom
shortly, may even dip the socket in water see if it does it then.
Martin.
Sent: 13 August 2008 18:47
Martin,
Reversing beeper?
Clive Marks
unfortunately NOT :-( the sound is strange ...like drilling in concrete and
coming from the front left of the dashboard.I also suspect some damp inside
the steering wheel 'couse the car had a lot of water under my feet while
parked at the airport in Stockholm(probably some hard rain)
but it is some electric annoying stuff at the steering wheel...
Lubo
On Wed, Aug 13, 2008 at 6:01 PM, Martin Naylor
<[Email address removed]>wrote:
> Hi,
> Hope it helps?
> Martin Naylor.
Lubo
It sounds a bit as if you have a relay chattering: are your fuses and
relays under the dash on the left hand side? Mine are under the right,
but then mine is right hand drive and yours may be swapped over. If it
got wet how about pointing a hair-drier up under the left hand side of
the dash for a few hours to dry things out?
Christopher Bell
________________________________________
On Behalf Of Lubomir Kolev
Sent: 13 August 2008 18:09
and coming from the front left of the dashboard.I also suspect some damp
inside the steering wheel 'couse the car had a lot of water under my
feet while parked at the airport in Stockholm(probably some hard rain)
Lubo
Christopher
that makes sense...it might be...the fuses and relays are there!!!I'll have
a look next week while changing the oil...thanks a lot :-))
cheers
Lubo
On Wed, Aug 13, 2008 at 9:01 PM, Christopher Bell <[Email address removed]
> wrote:
> Lubo
> Christopher Bell
> Lubo
> European Land Cruiser Owners Mailing List
> Further Info: http://www.landcruisers.info/lists/
On 13 Aug 2008, at 13:13, Lubomir Kolev wrote:
It could be water in the fuel filter, if it's a diesel.
Some LC models have a buzzer that sounds if water collects in the
bottom of the fuel filer, If your filter has a drain tap on it, try
draining some out and see if that stops it.
Neill Watson
thanks Neill !!!! I=B4ll see that too...
Lubo
On Wed, Aug 13, 2008 at 10:43 PM, Neill Watson <[Email address removed]> wrote:
>> cheers
>> lubo
> Some LC models have a buzzer that sounds if water collects in the bottom of
> the fuel filer, If your filter has a drain tap on it, try draining some out
> Regards,
> Neill Watson
