Hi John
I can probably scrape together =A3200, maybe =A3250 tops for the rack and
preferably a ladder as well. The rack needs to be strong as it will have to
put up with abuse and needs to be strong enough to stand on. Full length is
good.
Aluminium alloy would be good but I doubt the strength would be adequate so
galvanised steel is probably the correct option. Also steel is easier to
repair than ally should the need arise. However, if an ally one were to turn
up for the right money then I would seriously consider it. However, it does
need to look OK as opposed to "functional", if you know what I mean.
Thanks John
Pete
Peter Browning
Worcester Networks
www.worcester-networks.com <http://www.worcester-networks.com/>
01905 767200
01905 767185 (fax)
07973 625906 (mobile)
-----Original Message-----
Behalf Of John Byrne
Sent: 19 July 2006 08:37
To: [Email address removed]
Subject: Re: [ELCO] Billing 2006 - will anyone be there?
Hey Pete
What is your budget for the rack and what size Full/Short do you want.
Do you want it made of Alu or Metal and what load rating.
I ask because if there are more than you looking it may happen for you.
cheers
john 92HDJ 80 1HDT
